I have a 99 speedster and one engine runs, the other one doesn't, bought it used not running. last owner claims they rebuilt it using Mikuni parts and just to be sure, I ordered another set. I read somewhere that the lines from the accelerator pump have check valves. Are these lines OEM? If not, are you guys able to see this check valve? I cant get it started. I got it started one day, compression is good at 140-150. New rotary valves in both motors. Had it started on driveway one day and took it to water, only one motor started, the other was crank no start, took it back home, same thing, crank no started. Peaked in carb and noticed when pumping, the jets are shooting just air. The first time I had it started, it was pumping nothing either until I spray premix then it worked and fired up and primed as well. Then days after when I took it to the water, it would crank no start and wasnt priming. Are these lines shown aftermarket? If it is missing.... how many? And where can I find them? Also forgot to mention, when it did run or when it does run, my idle is fine.
