mdchachi
Dumb newbie here.
I was running at lower power for a while giving a tour of the lake.
Later, I tried to throttle up, the boat tipped back a little but thrust reduced
and it didn't sound like the water was flowing as if the intake was plugged.
There was white smoke billowing out the back when I did that.
Did that a few times before making it back in on low power. I thought
I must have got jammed up with seaweed. The engine itself sounded fine. Not
missing or anything.
So I pull the boat out and see water gushing out of an open plug drain plug
that I had neglected to screw in before launching.
When I looked in the engine compartment, the water was a good foot deep in there.
I couldn't tell if it was touching the engine or not.
I can't really tell how deep it got especially when the boat was tilted back.
The engine never sounded like it was missing, the symptoms were the white
smoke and lack of power. Before I put it back in the water and make something
worse I thought I'd better ask...what I should I do or check? Or should it be ok?
Thanks.
Thanks.
