oldmanactingyoung
Hi All
I just wanted to be sure i did this correctly. I have noticed on here that the basics of getting a used seadoo If you have good compression then you have a good base to work with. I purchased 2 used seadoos and want to get them back up to the standards i feel they should be.
They are super clean on the outside so i think the 1st owners took very good care of them. the young couple i got them from did not. they kept them looking good on the outside but not on the inside. they rode them till they had problems then parked them. so i am just checking to make sure I have a good base to work with so i can get them back to where they need to be. I got them Very cheap so investing a few dollars is not a problem.
On checking compression i took plug wire off attached it to the post then took plug out Installed Compression Gauge and bumbed engine one turn got about 140 of back cylinder did same to front and got about 140 from that one also. I did this 3 times on each one and got very good average ( not an expensive compression tester but seems accurate ) then i did same with turning engine over several times and would get 170 to 175 on each. i also did this several times and got same average 170 to 175 from each....which way is correct way to get correct Reading one turn or several ? ...no instructions with Compression Checker so im not sure...any help would be appreciated
