L. Dean Ficarro
Here is everything i can think to share about the build and event conditions:
EVENT
1. After idling under load for tuning purposes, i took the ski (98 GSXL) home to flush. Experienced a high 4500 rpm idle on the trailer so i backed off the idle screw. ~3000 rpm
2. Idled on the hose to flush, pulled hose, short-stabbed throttle to push water out and the engine engaged “high-speed jetting range”
3. The revs bounced 4500> 5k> 7k runaway
4. I hit start/stop> checked for a stuck throttle> pulled the plug boots off> it was already in a “hot fire” condition
5. Remembered the fuel shutoff, hit it, causing a shutdown all of that was maybe ~30 seconds
INFO BELOW
BUILD
engine- 951 with a fresh hone and new WSM molykote pistons, well within spec on all “thous” just under 170 psi on both cylinders
carbs- Prok filters w/ outer wear, choke delete and primer install
jetting set to “Ben’s specs” (85 lows and 167 mains with 2.3)
lows at 1 1/2 turn out
highs at almost close to 1/4 turn out
(Idle screw set to 1650 rpm in the water)
New full Mikuni rebuilds, pop-off tested to 10psi
Plugs BR8ES, gaps measured to spec, msd wire and boot
Oil pump calibrated
91 gas + 16.1 oil in tank for break-in period
WHAT HAPPENED and WHERE DO I START?
Bummed out, thanks for anything yall can add
EVENT
INFO BELOW
BUILD
Oil pump calibrated
