BoLongo
Yes it happened again, I am one of the most persistent guys you will meet; take a look at the photo below. Detonation is burning a hole in the middle of the piston and the top ring has caught the edge of the RAVE Valve Port and chipped the top of the piston. The piston is not white so I can rule out a lean condition. This looks like a classic case of timing being too far advanced.
This will be the fifth time I have rebuilt the top end of the starboard engine because of a ring catching an edge on a port. This is the first time I have seen detonation, but this is a stock piston which have softer crowns than aftermarket pistons.
This is a new used motor with the same result so it has nothing to do with the engine.
I have switched carburetor sets between motors and I have bought a used set which were all rebuilt with OEM carburetor kits. So it has nothing to do with the fuel system
The only thing still in the equation that has not been replaced is the ignition system. I have been talking with Jess and Nick at Westside Power Sports. They have been very helpful. I just bought a used coil junction box from them.
I will be setting up timing marks on the PTO and I will use a timing light to verify timing after the new top-end is installed. If the timing is still faulty I will have to replace the MPEM.
I wish I would have checked the timing after the first motor failure. I had that feeling but I did not follow through:facepalm:
