So my dad and I recently got ourselves a new project. A 1998 Seadoo Challenger 1800 with twin 787 engines. The oil pump is currently blocked off. Other than that, there is no other motifications to the boat.
We got it home and got both engines running fairly smoothly. Perfect! Now, our problem. A couple days after, we put the lanyard on and we got a constant beeping noise. Went through a couple diagnoses and figure out our engine temp sensor was going bad. After taking off the wire, we put the layard back on now we got two long beeps and when we try and start the engines there is a constant beep every second or so, never stops and one engine will turn over and the other won’t. On the engine that wouldn’t turn over, I heard a clicking noise in the solenoid. I went deeper into the advanced diagnoses in the manual and got 2 short beeps which stands for problems with the lanyard, DESS or MPEM. My first test- I unplugged the 3 wire harness connected to the DESS post. Tests the black/yellow to black wire and was 0 ohms.
Not sure what to do now. Any help is very very appreciated. I am stuck and there are not many dealers or mechanics around my area that will work on these boats. Thanks for any info.
