Any DESS key can be used for boat or pwc application. In candoo, you just add the key to the list. Each key has a unique number. Once you put it on the post the on board computer reads the key and checks it's internal list. So I have three keys programmed for the RXT and my Challenger.
It's well worth the 400 bucks to buy candoo as my local seadoo dealer can't handle boats.
Excuse my ignorance, is the programmer you are referring to the same as the tool called "CANDOO"?you can buy a new key but you need the programmer to add it to your MPEM.
Well that's a money saver. But makes you wonder why it was disconnected. The manual says you should get 4 chirps every 3 seconds if the key is left on the post while the engine is off. This is normal and to remind you so you don't burn down the battery juice.
