Hello all,
This is my frist post but ive been lurking since i bought my (new to me) 2017 gti se 130 last year. I added the factory bilge pump and factory depth finder last year before i even took it out. Both worked fine. I got it in august and ran it about 15 times untill i paid a dealer to winterize it and check for anything that needed fixed under warranty.
Ran it last week and the depth finder just showed dashes under the same use i did last year. Got it home and checked the fuse which is fine, plugs is fine (no melting or anything out of ordinary) and the connections are fine (nothing came loose) Also the epoxy is fine. It doesnt wobble and the unit is still very tight into the plastic pod thats epoxyed to the hull
The only 2 things i think it could be is that
1.) The pad under the depth finder is deteriorated and/or bad
2.) The unit died
Is there anything else i should look at before calling seadoo about replacement unit?
Thanks for any help
2.) The unit died
Thanks for any help
