morenaz0
Its warming up here in Australia and today i took out the boat for a quick spring run.
I was playing around with depth finder and was wondering if anyone actually uses this. I can understand using this when considering to pull up at a beach or anchor but apart from that, is there any other use?
If travelling at any decent speed, there is no way you could pull up in time based on the depth finder.
I'm considering removing the gauge, fitting it behind the dash so that the warning buzzer can still be heard and gauge can still be seen by lifting the console lid and replacing with a VDO boost gauge.
I believe the gauge is 52mm?
Thoughts?
Thanks
Thoughts?
Thanks
