I haven't done it myself, but I understand that if you use a hair dryer to heat the decal/graphic it will be easier to remove/peel off.
That said it the decals have been on for a while you will find that the gelcoat under the decal has not been affected by the UV from the sun as much as other areas and you may be disappointed with how it looks.
Good luck.
Mike
