WaterEnthusiast
Hi,
As stated in a previous thread, I recently acquired a 2008 Sea-Doo Wake 215. While I'm no mechanics and this is my first foray in boating and/or mechanical repairs, I've decided to educate myself and start by visually inspecting the Sea-Doo to see what needs to be replaced.
Here is a list of all the parts that I found to be either missing of damaged. I'd like to get advice on whether each of them should absolutely be repaired, could be repaired as an option, or isn't worth time/price) repairing. I noticed that the price for replacement parts isn't cheap, even for small parts that only cost a few cents to manufacture.
Here is the list (let me know if more information is needed. I found the following site to be VERY useful to identify each part number.
1- Anode zinc - 271001487: This is a round part that sits on the ride plate in the back. I have one on the starboard side but none on port side. What is the use of this part and do I need to add the missing one? (see picture).
UPDATE: It seems that only one anode is normally present on Sea-doos.
2- Hex Screw M6 X 20 (Scotch Grip) - 207362060: This is the screw to fix the anode zinc. Can I just use a regular screw from Home Depot instead or they are specially treated for water? What is "scotch grip"?
UPDATE: The scotch grip is a Loctite equivalent.
3- Small boot attached to the direction arm/shaft: 277001582: I am not sure this is the correct part number, and I am not sure if my part is damaged, missing, or if it is a simple matter that the rubber has worn/torn/heated. But something definitely isn't as it was when it got out of the factory. See pictures.
4- Boot to run the wire harnest to the dash board - Bellow - 269501557: When I open the front hood, I can see this rubber boot is torn at multiple places, but I suspect that when the hood is closed, although not sealed, there probably isn't water coming in (?). Also, could I just put electrical tape to "fix it" instead? Those boot aren't cheap and changing them seems to be a pain. See picture below
5- Rubber boot to protect the hood arm - Grommet- 293720078: Just next to the previous part, this boot prevent water from affecting the wire harnest, but I'm not sure there is causes a problem when the hood is closed. See picture.
6- Tow-pylon rubber strap - 293250183: This one is slightly cracked, but I am not sure if I need to replace it or if it is still working. It isn't clear what is the purpose of this part. Also, what is the use of the plastic hook just below it? See picture.
UPDATE: Indeed this part is what locks the tow pylon. I gather from the comment that it should be replaced. The user manual also states that is should be lubricated, which I agree. The hook is to be used with a strap below (missing/broken on my picture) to attach the ski rope to the pylon. I looked into it and they seem easily replaceable.
7- The fire extinguisher is missing the top handle... Does this renders it useless? Can I buy a generic extinguisher that will fit in the hood compartment/straps?
UPDATE: Yes, my extinguisher is not permanently damaged and I'll need to replace it with a Canadian one to legally drive my Sea Doo on the water.
Thanks a lot for your help/feedback on this.
