Danosll
Ok so I've resolved my cavitation issues, with a solas 16.5/23.5 , now to address a newly surfaced power issue. Old impeller would cavitate and motor easily hit 7300 rpm and 35 mph. Now I can only get 5500 rpm and 40 mph. with kids on board an extra 140 lbs plus me 180 lbs. So the power issue was there before. Just wasn't enough load with bad impeller. Here are the symptoms. Mid range miss actually appears rich at 1/4 throttle. 3/4 to full throttle no difference. Max rpm 5500 rpm . Can't plane pulling a tube . So good equal compression.155psi . Figure fuel although plugs look okay. Boat had idled a bit after wot run so inconclusive . Disassembled carbs and they were spotless no green ,jets ,diaphragms , filters, all good. Blew everything out. I was the first to disassemble these carbs. I will build a tool to do pop off test and pressure test . Although it seems okay I decided to rebuild fuel pump ,filter is always low. but I Can't seem to get parts from bombardier for fuel pump. So I read a bit about high volume pumps. In the meantime I bought and installed NGK red racing wires just to iliminate spark what I noticed was that the two primary coil wires were reversed white to neg. black to pos. has anybody ever experienced this? And would it describe any of my symptoms? Tell me what you think. I have yet to put my carbs back on waiting on fuel pump or not, if this May have been my problem. Thanks guys
