Crankshaft Position Sensor Location
Coastbuster2024
Hi Members. Dan new guy here. I have recently purchased a 2007 Seadoo Speedster that has a DTC PO 336. Crank Shaft Position Sensor. It says :WRONG RPM Detected".
I want to try changing,testing or cleaning it but I dont know where it is. Does anyone have a picture of the sensor in place on the engine? It's a single engine Rotax 150 HP. ENGINE FAMILY 7BCXM1.504GN. Thanks in advance. P.S even if I knew what wire it was at the ECU then I could follow it back to the sensor.
On my 4tec motor I believe it’s as your looking down in motor compartment from back of skis it’s just to the left of the drive shaft slightly under the motor
