68ragtop
I thought I would share something with you guys that I found very interesting. Last spring I picked up a 1999 Challenger with the twin 800’s. The boat had been sitting for two seasons after the previous owner brought it out of storage in the spring of 2013 only to find that the starboard engine was seized up. Thinking it was the starter, he brought the boat into his service center only to have them inform him that the engine was hydro locked with injection oil. They told him the news of bad crank seals & gave him an estimate of $2800 to replace the engine. So he towed the boat back home unrepaired and it sat there until I purchased it & brought it home this past spring.
After removing several mouse nests & one dead squirrel, I got the boat cleaned up. I started to go through the vitals on the engines to figure out what was what. I did in fact find the starboard engine locked and full of oil, Just as I was told it was. The oil in the engine was a bright blue color that matched the oil that was in the tank. I contacted the previous owner and he informed me that the oil he was running Pennzoil synthetic injection oil. (possibly the cheapest synthetic injection oil on the market) I drained the tank and replaced it with XPS II, then Siphoned out all the oil form the engine as best I could. I went through the carburetors on both engines, & they were both soon up running. The now running starboard side smoked enough to fumigate the whole neighborhood as any oil submersed engine would I suppose. It was rather comical & I’m thankful no one called the fire department. ☺ After a few days of tweaking & more cleaning, I took the boat out on the water to test it. It was running & performing very well and just needed a few minor carb adjustments. Now that I knew there were no other major internal issues, I decided to dig deeper into the oil seals. I Pressure tested the RV case, and found it only lost about a pound over one day. It seemed like if it leaked, it was probably rather slow. I then looked at the injection check valves. No problems there, Both of them held just under 2 pounds of pressure with zero loss in 24 hours.
So, it was definitely looking like crank seals were the culprit. I decided to flush out the RV case. What I did was hook up a vacuum pump to the RV oil return line to the tank. What came out was rather dark & dirty looking. It was obviously a mixture of several different types of oils over the years and ironically none of it was really blue like the clear oil that managed to get past the seals and into the case. Once the oil was coming out in that reddish-brown XPS II color I decided to start up the engine and siphon some more while idling on the hose. The oil came out a smidge dirty again but it was looking good. After wasting about 1 quart of injection oil, everything was flushed out and I hooked the return line back to the tank. Now all I could do is have some fun with the boat and see what would happen. We brought it up North for the Fourth of July weekend and ran it all weekend long. The boat ran fantastic & we had fun tubing & skiing. When the holiday was over, days turned into weeks, and weeks turned in the months and sadly the boat did not get run again until I brought it home to winterize it just 3 weeks ago. Rather then attempt to just start the engines I decided to remove the airbox off the Starboard engine and take a look in the case with my borescope. To my surprise there were only small, normal sized oil puddles in the bottom of each side as if it was only run just yesterday! I was amazed. I fired up the engine and it hardly smoked at all. I fired up the portside engine & that one smoked quite a bit, But nothing too alarming.
While its just a strong hunch at this point, I’m starting to believe that RV oil maintenance may be somewhat critical in these engines. Especially the ones that have seen endless types of who knows what oils from how many past owners, & possibly even moisture contamination? When I was done, I left the drained out case oil in a clear measuring cup. After a few days some of the oils seemed to start separating to the bottom. Possibly moisture? Not sure, but it wasn't what you want in your RV case. If you think about it, that oil never gets moved, recirculated or anything. It just sits in there. It just might be possible that some of these leaky seals, might be due in part to all the “crap” that is trapped on the other side of them. So before you stick a fork in your crank seal leaker, I would suggest at least checking the injection check valves, then flushing out the RV case with a good quality oil & see if anything changes. Its easy enough to & sure worth a try.
I may get some flack for this idea & Maybe I got lucky, but I never pulled a bolt out of the engine & it only cost me a quart of oil & some time to fix. I don't think its going to cure an engine thats filling up with oil in one week, but for sure worth a try on the the seasonal slow leakers.
I’ll confirm in my finding spring, But so far Im feeling pretty good about it.
