kcr357
I just picked up a 98 GTX, great shape but the motor is locked up completely, not movement in the crank, rods or piston. Looks like a bearing went out, hopefully when I get everything apart Ill be able to tell why. SO far, Ive been spraying pblaster down the cylinders, and today I took off the bottom crank cover and sprayed more lube on the bottom side of the cyl. I tried beating the hell outta the cylinders with a hammer and piece of wood, but no luck so far. Anyone got a trick for getting stuck cyl off?
