Hi, I brand new to the site, and just got my first Seadoo the other day. I was wondering the seller said the boat only had about 40 hours (hard to believe) and never had any major repair. But the first red flag was one engine (the body underneath the cover is silver and the other is white, is this common or do you think it was changed. 2nd there are ports on both sides for the blige fan but only the starboard side has an actual fan? Is that incorrect, and third the starboard motor when started for 5-10 seconds on trailer shoots right up to 3.5 k and the port does it gradually, also I took the handle assembly with the throttle knobs out and it seems the cable is loose. When I adjusted it the motor ran at 2k and the port at 3-3.5 what is normal rpms? The fuel gauge dosn't work, and the seller send sometimes it does that and he would tap the fuel tank and it would start working, and last but not least there is oil all over the port engine from I guess the holding tank? Any help would be greatly appreciated.
