Couple of quick questions
prairieboy
First off, if I pull my carbs off to work on them over winter, what can I do to plug the fuel lines so they won't syphon out of my 3/4 full tank of gas - and when I pull them off the carbs - will there be a ton of fuel that will come out.
Second question is when I am going to fog the cylinders, where do you ground the plugs wires to in order to crank the engine over to get things evenly distributed.
Boat is a 99 speedster.
