Palm Bay Chuck
Another question that should be quite basic. I replaced my solenoid and starter. The starter works like a charm now and engages fine. The Solenoid did not have any indications on it, such as an 'I' and 'S' that are mentioned in other threads. The OEM solenoid did have the letter 'A' in a spot on the top and the new part had a marking there that wasn't a letter. It looked more like the degree sign '¬', but that was the only marking.
Anyway, my question is simple, if I had the solenoid flipped and wired opposite, would that prevent any spark? Also, would it prevent the solenoid from working at all? (I'm gathering that the solenoid would still work as there is no polarity requirement or flow direction requirement.)
Thank you!
Just trying to avoid flipping it all around if I'm barking up the wrong tree.
Thank you!
