Corrosion preventer
jjj
I have checked my local Seadoo dealers web sites (& other sites) for corrosion preventer part # 219700304 which should be used on the drive shaft per the service manual for salt water use and they don't seem to have it. Does anyone know if this is still available or what would be a good replacement?
Timmy is correct. Use the cheapest spray silicon you can get. They are all the same. I use WD-40 also on my stainless steel parts as well. I buy both products by the case lot...:)
Karl
It isn't so much what's in the can as just the fact it's sold by seadoo. I'm sure you priced their oils...they don't make oil either, they just package and sell it.
Karl
Karl
I know you are correct on that!! What is a good substitute oil for a non s/c 4tec engine oil and the other spray lubes Seadoo calls for.
Thanks,
John
