JPass
So I was sick of looking at the corrosion on the reverse bucket brackets on our boat. Being that the day started off crappy, we decided to remove them and clean them up. Well.............not so fast said Mr. Corroded bolts. 1 bolt on each bracket wouldn't budge. Soaked them in some Kroil. Still nothing. Had to break out some special tools. Each bolt took about 30 minutes to remove.
We were just talking about anti-seize in another thread and it holds true here. Had the previous owner used some anti-seize, I wouldn't have had the issues I had today. I'll have to get some new hardware later this week before I put everything back together. I wound up using a special wheel on my die grinder to remove the corrosion and just repainted them with some Rustoleum.
If they survive, great, if not, I'll have them bead blasted and powder coated this winter. I wound up pulling the pump cones to check everything out. All seems good to me. Holler if you see something suspect. The brackets are currently drying out back. I'll post pics in a few when they're done.
I also noticed a little sealer between venturi and pump housing. I thought this was unnecessary?
