cooling system bleed outlets
speedster4us
I have a 1997 Speedster and I cannot seem to find them, according to my operators guide and the fiche online they are located at the same place the tow loop is, on each side of it. But the loop is solid metal and there are NO holes on it or in it. Is it possible that is exits through the exhaust the goes through the rear of the hull.
I've got the same question. The tow loop piece is solid with no bleed outlets as the manual says. What gives people? :D
Found Them
Tobasco, and other who that may not known the answer. After paying good attention to the tow hook area and running on the hose several times. The bleedouts are located UNDER the tow hook that has a little bevel on it.Take a look there cause they are NOT visable...
