bigtexan99
Took the boat out last week and the telltale stream from the water cooling line was erratic.
I had previously relocated the stream to the side of the boat near the throttle, so I routinely check the stream during operation. Normally its hot and steady.
This time it was spurting on/off, then over time would mostly be steady with occasional spurts. The temp of the water was hot / normal.
After the engine was off for a few minutes, started the engine and could feel AIR coming out the hole for a few seconds before the water started spurting.
What should I check first?
