wasn't aware of the coolant drain plug?
if the ski hasn't been started I souldnt be seeing fresh coolant on top of the plate should I? this would hence the drain plug you mention?
I have been unable to get past the caption in that link showing above for atleast a month now, that's even double checking the numbers I enter into the box match the green numbers.
Agree, the leak doesn't seem to come from drain plug, underneath. Only way to pinpoint might be to drain antifreeze and pressure test using 10psi air and soapy water from outside to detect location of air leaking. I guess the leak is outside the hull, thus it seems the plate itself is the suspected culprit. The plate is two halves I believe, with some sealant or gasket between them, not sure if they can be separated and resealed or sealed from outside without removing from hull.
Not sure how the item #16 and #17 can be responsible for leaking outside the hull but I haven't disassembled one of these so no direct experience. I think the plastic nipples are brittle and easily broken though, you might need replacements if you remove the ride plate?
Here's that drawing that shows more detail, sorry I dunno why the link isn't working:
13~15 - 271001557 RIDING PLATE (INC 13-15) 1 254.99
16 - 293710111 STRAIGHT PLASTIC FITTING 2 5.99
17 - 293300121 O-RING 2 6.99
9 - 293800066 SEALANT, LOCTITE 5900, 300 ML @ 41.49
Item #14 is the drain plug, it has pipe sealant applied to keep threads from leaking:
15 - 293800013 LOCTITE, PIPE SEALANT, 250 ML @ 63.99
Item #21 is a gasket of some sort, not sure if this is important or can be reused:
21 - 293250087 GASKET 1 5.99
