Coolant leak
GLVandy
2005 SeaDoo Wake leaking coolant outside hull near impeller housing. Noticed coolant leaking and when pulled out of water a steady
That 4tec has a closed loop cooling system,,,where the ride plate is the "rad"...if you have an automotive type pressure tester,,,that shoukd help you gind the kesk...often its just a loosening clamp.
No,,,remove the intake oses etc,,,to give you a lear picture of the hose connections,,,most are low and deep...it could be as simple as tightening hose clamps...also...make sure you look at the hose connection where the hoses go into the ride plate,,they are known to leak,,,or the fitting breaks,,,its way back,,,so hardly anyone sees the leak,,,,I have a specific powerful flashlight for this procedure,,,It will be your while to have a narrow super powerful lots of lumens,,,flashlight for the deep dark crevices of a watercraft.
