Water sports
The hole should have the plug in it.
You need to spin the retainer plate 180. The little nub fits in the little hole. The plate shouldn’t be bent it should be flat.
Question, with the screw, do I Loctite this in, if so what type of Loctite do you recommend. My issue is the screw is a little loose as the thread appears to be slightly cross threaded.
