Mr Sniper is right. :agree:
If you can imagine a team of mules, and one of them is a race horse. The race horse is going to be out of step with the others, and wear himself out, at the others slow pace.
So, if one has more compression than the others, then the overall balance of the motor is going to be off. Most of my experience is with single cylinder motors.
This is one reason the gray fuel lines are so bad. On 2 carb models, one carb and cylinder can run lean, and upset the balance of the motor, and overheat one cylinder, and wear, and upset the compression of ONE cylinder, without the other. Now, we have a "loping effect".
So, I think gray hoses are bad, but particularly in dual carb models.
PWC Blessing:
So, may your fuel be clean, your carb filters be clean, and your compression even, and you wife have the house clean when you get home!
(Wink)
Nate
