Just finished an install on a SBT engine on one of my 2 1998 GTX's. Did a compression test and had some very low readings in the 120 psi range and was very concerned. Cross checked it with my other GTX and was getting about the same readings. I know that ski runs great. Have been reading a lot of threads on here during my install and have gotten some good advice. Also, have read several times and recomendations by DRHONDA that when compression gets below about 135 an upper end rebuild is recomended to prevent lower end damage. I thought I was looking at not only a problem with my new install but also a upper end rebuild on my other. The way the ski ran had me wondering though.
I ordered a new compression gauge from my SnapOn dealer and re-checked. Bingo, both skis reading in the 145 range.
Point is, make sure your tools are accurate. If something doesn't seem right, double and tripple check before you make a major decision...
