I have a question about compression testing. I inherited a 1997 Seadoo GTX. Fairly typical story. Someone got it, not running, took it apart, messed up the carbs, let it sit for 2 years. Eventually they decide to get rid of it which is where I come in. I like a project.
So, I have now pulled the motor from the ski. It spins easily by hand and develops compression but I have no idea how much. I don't want to go through the process of putting new carbs on it, reinstalling it etc just to find out the compression is low. So here's my question; Can I hot wire the starter and spin the motor and get a useful compression reading? Remember there are no carbs installed at the moment. Will the motor suck air and compress it normally? If so I assume I want a minimum of 130 or so and ideally 150psi.
If you know and can let me know that would be most appreciated.
