blueprint83
I have a 1996 Seadoo GTX with the 787 motor. The top end was redone about 3 or 4 years ago and I just recently did a compression test on the ski and it was 124 psi in the front and 150 in the back. The ski runs great. but is that 26 psi difference anything to worry about. and do the rave valves effect compression tests as well as the charge of the battery.
Thank You,
-Chad
Thank You,
-Chad
