Compression?....
Hola y Bienvenidos al foro De-mar-Doo. ¡Alegre de tenerle aquí como un nuevo miembro!
The 145 psi is really good. That's what you can expect. The 110, I'd double check that one a couple more times. Maybe run the engine, warm is up a bit, then shut it down and check it again. If you have a ring that might be sticking, you may try a cap full of Marvel Mystery oil in the cylinder, let it sit over night and the next day, roll the engine over to blow out the oil and try a compression test then.
How do your rave valves look? They should be cleaned yearly. If it's been a while, you can tell what how the engine has been treated by the carbon build up on the guillitone valves. If your not familar with the RAVE valves, there are several post in the forum that refer to them and their cleaning.
If the compression doesn't get better, it may be that the jug is scored from something that got into the piston. Normally, both pistons wear the same, so the compression should fall off fairly evenly. Sea-Doo doesn't recommend an engine overhaul until the comression falls below 100 psi, so for me, I'd ride a summer or two and just keep a check on the compression.
One more thing. If your still using oil injection, make sure the oil line going to the bottom side of the rotary plate is providing oil to that piston. Losing oil from a clogged injector may cause the lower pressure and will at some point, cause it to go flat or seize up on you.
Welcome to the Seadoo Forum....
