SeptemberC
So here's what we did today. . .I took the fuel baffle out and installed a new float. . .That didn't fix it. Took it back out and cut it open and the fuse was bad. So We fixed that. Put it back in and voila it worked.
Changed the spark plugs. Changed the lube in the pump. . .that went smooth except for we found no cork or rubber washers on those screws. But the oil looked great. We attempted the Stator oil change but could not get the stator housing off. ..Not sure if I am calling it the right thing. . .so we skipped that (for now).
Put her all back together and took it to the river. Left it on the trailer and started it. It smoked a little. Then it died and we could not get it started again. So there on the river we put the old spark plugs back in but it still would not start.
Upon further investigation the carbs appear to not be getting any fuel. ALSO there is a module on the right side (as you are standing in the boat looking at the engine) that was clicking. It Clicks when you turn the battery on and when you turn the key on before it starts turning over.
What have I done that would make it not Fire? Could that module be bad? Coincidence? I had NEVER heard that clicking sound before.
