Service!
I see your RXT is a 2005 model. Is it still under warranty? If there’s no penalty in doing it yourself, why not save a couple extra bucks. Most of the ten hour service is inspections.
Here is a list of things that have to be done for the 10 hour service.
1. Change the engine oil and filter, including the “O” rings.
2. Inspect the supports and rubber mounts, seals and fasteners and the exhaust systems fasteners.
3. On the cooling system, inspect the hose and fasteners, check the coolant level.
4. On the fuel system, the engine management sensors need to be inspected. (you may need this done at the shop, but there just looking to make sure there is no broken wires or sensor clips).
5. Inspect all fuel rails, fuel lines, connections, pressure relief valve. (again, this may be done at the shop).
6. Inspect the fuel tank straps.
7. On the air intake system, inspect the throttle body.
8. Inspect the air silencer, make sure there’s a good fit and it’s tight.
9. Inspect your electrical system. Here, you’ll want to go over every wire you can see. Check the connections for corrosion, make sure no wires are broken. Look over the ignition wires and spark plugs. Clean your DESS lanyard with warm soapy water and let it air dry. Check your battery for proper cleanliness and make sure the connections are tight.
10. Look at your steering and shifter cable. Inspect it for any wire strands that have separated. Lubricate and adjust as needed.
11. Inspect and adjust the O.P.A.S. system as needed.
12. Inspect and adjust your VTS system as needed.
13. Inspect your ride plate and cooling system. Look at your drive system and your thru hull fittings.
14. Check your bailer pickup tubes. Make sure they are in place for proper operation.
That’s about all that’s done. If you read it all, there really isn’t that much to do with the 10 hour service. The 25 hour and 50 hour is even easier than that. But the 100 hour service, that gets a bit involved. You’ve got to test and replace a lot of stuff.
I hope I have helped you save a few bucks!...With the economy like it is, I’m just praying gas doesn’t go up to much come spring. I can’t afford $3.50 a gallon to go play!........:cheers:
