kinghugy Member Apr 23, 2024 #1 Is there a way to read fault codes on a 2012 Sea Doo Gtx from the on board computer when the check engine light it on?
ski-d00 Well-Known Member Apr 23, 2024 #2 Yes, press mode while the check engine light is on, until you see a fault codes menu, press set and arrows to see the codes. If you shut it off, good chance the codes will no longer be active and the fault codes menu will disappear.
