Code P0505 on a 2008 RXT215 Any ideas?
jwalts27
I have an 2008 RXT215 and just today this code came up P0505
DLA output stage cutoff memory cuircut or output stage fault or open circuit or short to 12V
Any ideas of what this is?
I find 1 instance reading Google results where the dealer found the idle sensor was bad and causing this particular P code on an 06 RXT... you could try replacing the idle sensor on the engine and just see if that solves the problem or not. Otherwise, probably time for a trip to the dealership yourself... hope not though! Is it beeping periodically also?
- Michael
No it has not beeped for me and seems to run fine. I know it is a code for the air bypass valve. I was wondering if anybody ran into this before, if i should try to clean the valve or just replace it.
So after pulling the ski out of storage for this season i decided to bring it to the dealer to finally fix the issue i listed above. They are telling me the ECM is not sending the proper signal to the idle bypass valve. Has anybody seen or heard of this issue before?
