Closed Loop Cooling System Questions
asianlink37
Hello, I'm new to the forum. I was wondering if anyone had any input about what they do with their closed loop cooling systems when they bring their skis out of storage. I just bought my ski this past August and only got about 12 hours put on it. I have every intention of changing the oil and spark plugs next spring but I was a little curious about what maintenance any veteran Sea-Doo owners did as far as maybe replacing the old antifreeze or what...? Any feedback would be appreciated.
Thanks,
M
Nothing for the most part.
Test it to see where the freeze level is. Feel it, if it is slippery then you are fine. If it feels like water with no slipperiness to it, change it.
The anti freeze aspect can last many many years. The lube protection can fail after two-years.
The lube aspect acts as a coating to protect many things such as pumps and metal parts. It is a rust prohibitive.
Thanks for the info. I'm pretty good with everything else pertaining to the maintenance of the ski, it's just a friend of mine (diehard Yamaha fan) swears that the CLCS is just one more component that can malfunction and cost money to fix! I see it as keeping harmful saltwater out of the motor since that's predominantly where I ride. It's actually next to impossible to find any kind of advice on this topic, trust me I've looked.
I'm the original owner of my '05 rxt. I've never had to so much as flush the system. I did clean the ic a coupla times.....that's it.
edit...Not a maintenance/mechanical issue, I also swapped my thermo for a cooler one.
I like to change the coolant on a 2 year cycle, and I believe this is also a Seadoo recommendation. I agree with the others here, the coolant will more than likely last for much longer than 2 years; but how do you really know. Sure, there are testers out there but I just don't trust them.
I worry about the coolant's ability for corrosion protection. When new it has corrosion inhibitors and lubricants to keep the system clean and sealed. When the fluid goes bad, things start to happen fast and you get internal corrosion, seals start leaking, etc. The corrosion starts in parts of the engine that you really can't see and you might never know the degradation is there. I have seen old car engines and radiators that have not been maintained and it's not pretty. The 4-tec cooling system is aluminum and some of the parts, like the heat exchanger, have very small tight passages that could fail with the least amount of internal damage. This can be costly to fix.
I prefer to error on the side of safety which is why I practice preventative maintenance, maybe a bit to the extreme. Why not? Changing the coolant is one of the easiest and inexpensive maintenance items to do on these machines. I am a big fan of the Seadoo closed loop cooling system and it puzzles me why more marine manufacturers do not use something similar, especially for salt water use. I see it as a definite benefit and not a drawback by any means. Let us know if you need any tips doing this for the first time yourself.
It is so easy to do and inexpensive.
