H€PHÆ$TU$
I've heard it repeated everywhere, this forum and others, that on the fuel pickup in our boats, the RES port straw dips down lower in the tank than the ON port straw does so as to give the operator one engine when the tank runs low instead of running both dry and getting stranded. This is not true, at least on my boat, and here is why.
Here is the upper section of the sending unit from my boat. It is obvious that the RES straw is longer than the ON straw, which would result in the RES being able to suck from a lower point of the tank. Different boats use this different ways, but ultimately the result is to have a reserve capacity to get you to a fuel source if you run the tank low. But this is not how it works on my boat and probably not on other boats as well. This is important to know if you own a boat and think you have a reserve capacity.
They obviously use the same top section in many applications. But what differs is the bottom section of the sending unit:
Notice how the ON barb is longer than the RES? This takes up the entire void length of the reserve straw in the top section and effectively eliminates any reserve capacity. I've confirmed this by pulling the sending unit and putting it in a glass of water. I can suck water like a straw from both ports at the same water level. There is no point at which the RES port siphons before the ON port.
Look at the factory parts manual. They obviously use a generic pic of the sending unit because it even shows one without the larger cup that my boat has:
And now look at this eBay listing for sending unit repairs:
https://i.ebayimg.com/images/g/rw4AAOSwIgNXsNar/s-l1600.jpg
The tops of most of the units are essentially the same but the bottoms differ greatly.
So long story short, there's no reserve in my boat, probably not others as well. Both the ON and RES port do the same thing. They're only named differently for economy of manufacturing scale.
