Cleaning up!!! Xp/sp/speedster/sportster
d!face
The time to sell all of my parts has come. I have a little for some and alot for others. Theres a decent amount so i will fill you in as best i can on every individual part.
Contact: PM or Call/Text: 6zero98six87eight41..
**IM LOCATED IN SOUTH JERSEY, ZIP 08093!
**ALL PRICES INCLUDE SHIPPING AND PAYPAL FEES!!!!!! IF THERES NO PRICE THEN ITS A PICKUP ITEM ONLY!!!
**Engines/ Cases**
Complete 787 long block, motor has binding issues i believe in the bottom end. is not seized. Might be easy fix, parts, or core. $275
717 complete long block, loud knock in top end. ran when removed from 97 speedster. $250
657x complete long block. ran when removed from a 95 speedster, could use a good cleaning. comes with exhaust pipe. $450
787 jugs with head, light surface rust, nothing major. will seperate. $70
787 stock dome $30
657x rotary intake cover, super clean $40
**Drive Shafts / Pumps / Nozzles**
20" in length, not sure what its out of $30
17" in length, not sure what its out of $30
17" in length, not sure what its out of $40
Twin Jet Pumps off a 97 Speedster, both were rebuilt 2 years ago but never put in water. the one with the shaft is stuck i havent tryed to free it. both have new bearings, seals, resurfaced oe impellers, will separate nossles $150 each
3 steering nossles (non-trim) (5 available depending on pump setups) good shape no cracks or corrosion. $40 each
**Electronics**
Gray box assembly out of a 97 speedster. MPEM is shot, good for core or repair. Rest of box is really nice, just missing starter solenoid. Comes with lid and gasket. $200
Complete gray box out of a 94 xp (i think) MPEM is 278-000-071, made on 4/14/94. some rust on starter solenoid from getting fresh water in it. mpem fuses are all good but couldnt test it. good for parts $100
Continued:
Hacked gray box from a sp. all ends out of the box are cut, insides are very clean. mpem fuses good but couldnt test. MPEM 278-000-262. 12/2/92. $100
Complete gray box out off a 96 xp, box is clean, mpem fuses look good but couldnt test it. MPEM 287-000-510 3/7/96. NO KEY! $100
Gray box from a 95 xp. missing mpem. good shape overall. $50
**JET BOAT SEATS** **PM ME FOR PRICE**
Very Nice 3 person seats from a 95 speedster, top and bottom in very good shape. no tears, fading or holes. Need a good cleaning. I only have this set no others for a 95.
Partially wrapped top and bare bottom from a 97 speedster. Crap job on the wrap job. Inner forms are in great shape.
Seat foams from a 97 speedster
--Port side, single seat, outter bottom foam.
Port side, single seat, upper back foam
**Misc**
Carb Cover, Spark Arresters. 3 Sets Available. $30 each
Rear Cargo Cover from a 97 Speedster, no cracks, good shape $60 NO SHIPPING
Water boxes from a 97 Speedster. Good shape. $35 each
Choke Cables from a 97 Speedster $25 each
3 way switch (lights, bilge, fan) $30
Hood from 95 Speedster. Color looks great, Has two outter rpm gauges, dont know if they work. $60
I need a Tach plug and wires for a 1999 Sportster 1800 (twin 720) I am putting the tach in a '96 SPX 720.
