Cleaning my fuel injectors.
laze
You think if i put a STP Fuel injector cleaner into my gas tank.. It would clean my whole fuel lines and injectors good? Would it work good on a jet ski? And how many times would i have to use it, For it to be clean really good. Someone recommended to use that after i told him my little problem.. The jet ski not turning up as fast as it should.
Fuels.......
If your using a good quality fuel, your already cleaning your injectors. All the major fuel companies add injector cleaner to their products because of the engine requirments of today.
Chevron for instance uses "Techron". It's a detergent additive that's meant to clean injectors and reduce carbon deposit build-up on the valves.
I can't answer your questio as to whether or not it is recommended to add something like "STP" because, that additive may change the fuels properties enough, that you'd likely have to add more oil because it may or may not boost the octane in your fuel.
In my opinion, I'd not use it. If I had question as to a bad or dirty injector, I'd pull it and test it. You can tell when operated whether you get a dribble of fuel or a fine atomized mist.
Unless trash got past your fuel strainers, I think it un-likely that your injectors are dirty.:cheers:
Well i been using regular fuel gas. I didnt know a jet ski had to use the best gas lol.. But ya. Thanks for your advice.. Ill prob sell this jet ski anyways and get me a faster one
No you do not need special gas. All types of companys and different octane rating gasolines have this in them. If the gas was in the tank for a while this could have been the cause too. Drain this and refill.
Ya.. I must have fresh gas now.. lol i ride every weeekend. And it almost goes empty and i have to fill it up O.o.. But some dude that fix jet ski.. He said to put fuel injector cleaner. I know the most expensive gas as treatment for it.. But down here in miami.. It cost an arm and a leg lol.
Clean Gas
Smoke pollution as become the main the drop back for the todays environment pollution. Most of the pollution come from the vehicles. For reducing that pollution a new technology gas i.e clean gas as been introduced which does not contains the harmful contains which spoils the environment.
Here is a link that might be useful: Clean Gas
I just add about a gallon of water to the fuel. And some emulsifier. This keeps it in TIP TOP shape!
(Sorry, moderators, it just seemed like the thang to say!)
N
NO spammers allowed...
If you want suggest some ideas to the forum as an opinion that's fine. If you persist to add your comments as a link to your web site you will be banned as a spammer from our forum. This forum is a friendly place for seadoo owners to learn and gather advice and information about their seadoo product. If you have some information pertaining to help our members on the forum fine. If not, you will be banned and your posts will be deleted.
Karl/ Moderator
Karl/ Moderator
I see his/her one thread has been deleted... pluse there watercraft model is a HI must be some new auzie model that runs on water and wiskey :hurray: I havent been on here aslong as some of you other folks but i do see a trend with new member that join this site including myself and that is most new members first post is Hi and i was wondering if someone could help me with my problem, Most people dont join to try and sell there product. This is truly the best seadoo site on the web, no other site out there has as many member that will bend over backwards to help out other people with the same intrest. Keep up the great work everyone!!!:cheers::cheers::cheers:
Here is a new twist to aditives to fuel most gas now {in Canada} has 10% ethonol for reg. fuel but no ethonol in the higher octane grades and after reading I have found out the ethonol is making the engines run like crap so I now use a higher grade of fuel with no ethonol and find my truck and ski run great. So heres my ? why do thay not put ethonol in premium grades of gas if it is better for your motor it should be in all grades.:confused:
Ive also head that to much ethonol can be bad, Im guessing it all comes donw to money and how much they can make. gas companys dont care about there customers but they will go bankrupt in the VERY distant future.
Water n whiskey??
G'day there... (Sportster Joel).... Water and Whiskey for our Aussie model sportsboats?? WHAT THE ....? FYI .. we "AUSSIES" feed our Sportsboats "BUNDABERG RUM" ... know as 'BUNDY RUM' to all us "RUMPIGS"!! Water and Whiskey.... thats' for them "PUSSY" boats they call them.."YAMAHA" .. or "POLARIS" .. or even "KAWASAKI". :rofl:
"BUNDY RUM" contains plenty of ETHANOL... BTW. Never had a Problem!
Cheers:cheers:
BTW.. for all those "HI" THREADS.... you might find this site useful... www.@!$$OFF.com.au!!!
Best way to clean those fuel injectors laze is to take them out and get them "flow tested" by a fuel tech. Peace of mind is a good thing when it comes to diagnosing problems.
