Guest_User
2 stroke oil leaking. this is clean unburned oil leaking. where could it possibly come from???
I have been all over this boat from day one of ownership and replaced a bazillion items/parts.
I am premixing.
ALL hoses, line, clamps have been replaced. I have a minor drool of oil out the bottom of the tank which is evident by running down the split loom covering the hose and collecting under the Port engine. That is not the issue.
I have OIL all over the back of the Starboard engine where the ID tag is. it is leaking enough to wet the back of the air box, run down either side above the PTO fywheel area...
Under the stainless cover that holds the electrical tower in place is DRY, so the seal isn`t leaking.
I had first thought it was oil from the balancing shaft gear reservoir, but it is not...
I am not 100% familiar with these 787`s. are there any gaskets, joints, fittings, seals, case surface issues that are know for this?
when running the boat earlier this year, I did not push the boat due to repairing and fixing ongoing issues. Now that everything had been addressed and now running at max rpm`s, the last 2 rides were running a bit harder and between 6-7K rpm`s which is what the boat was designed for... this is when I noticed the presence of a lot of oil on the starboard engine. under the engine is damp, but not soaking wet like the back. the hoses to the RV are secure and not dripping oil. there is a new stainless clamp along with a safety zip tie securing the new 1/2 ID tygon hoses.
I didn`t think there was any pressure in those hoses anyway that supply oil from the tank to the RV shaft/bearing.
so what can I look for or check? what could possibly be leaking that amount of oil to create a mess that runs down in to the bilge?
at least it is the end of the season for us, and the boat is being disassembled for winter storage. I already have the drive line/pumps and various parts on the shelves in the garage.
I plan on pulling the engines and storing them indoors.
I hope to find where this leak is before my reman warranty expires... Thanks.
I am premixing.
