The check engine light has flashed on and i pulled a P0116 fault code. That is the engine temp sensor faulty. could this be a problem with the waterpump or thermostat. I am going to test the resistance on the sensor tonight and pull out with harness hooked to sensor and heat up with heat gun to see if it throws the same code. any input on this??
thanks
thanks
