05-200 speedster SC 370HP----
First ride after de-winterization and all is fine for bout 30 minutes then the Starbord Yellow Check Engine light goes on and stays on with the LOUD constant BEEP!, I pull the key off and it clears? no clogs in the propulsion, both props aren't cavitating or jammed up...it did it 4 more times randomly today
After searchin the forums the CANDOO system is mentioned to read codes but I cant drop $2k+ on a code reader
Any thoughts? insight into this...never had this problem Ever for 6 yrs of running and havent changed a thing, just put fresh gas in and ran it-Oil level looks a tad high on both dipsticks though?
Thx in advance
Thx in advance
