I have a 2001 GTX DI, I took it to a Mechanic in the spring and told him to check the charging system, because last year I had to keep charging the battery everytime I used it. He told me everything checked out OK. So I replaced the battery and it still isn't holding a charge. I took a voltage reading at the battery, Before I started the ski it was 12.2 volts, while it was running I took another reading and it was 11.5 volts, and going down. I gave it alittle gas thinking maybe it needed more RPM to charge, but the volt reading never went up. I think it should work like a car system and read about 14 volts while running. is this not correct? if so where should I look next. I do work on my own cars and bikes so I beleive I should be able to work on the ski.
