Trickle or Tender?.......
The answer to this question actually is all determined around the charger you have.
If you've bought a specific battery tender, it's just what the name says it is, a "tender". This is meant to be left on 24/7, 365 days a year. A true tender uses smart technology to know when the battery is dropping in amps, turns itself on, then when the battery is at capacity, it turns itself off.
A trickle charger or any other type charger is just that, a charger. It will not turn itself off no matter if you've got it on a 3 amp trickle or a 45 amp start. Left un-attended, the battery will begin to gas and evaporate the water inside the battery, creating explosive conditions if kept indoors (like a garage).
So, according to what you actually have, you can decide on what type of maintenance you need to apply to your battery.
Oh, BTW, a tender can be used with the battery connected to the watercraft. If at all possible, remove the battery when charging. If it's in a hard to get to place, removing the ground strap will work. Although, you may not damage the electrical system with the battery connected while charging, there stands a chance that you'll at minimum, blow a fuse.:cheers:
