changing impeller & fuel filter
Sean C. Brooks
i have a seadoo millenium edition GTX. how do you change the impeller and also how hard is it to change the fuel filter, i can see where it is but do not want to twist it and break the housing??
thanks,
sean,
for filter, just twist, stick'n from crap built up around o-ring. For pump, remove it, unbolt'n the nozzle assy..etc, then pull, might be siliconed up, so, pull harder, then you'll need impellor removal tool, but vise-grips and bench vise will work, also, since replac'n the impellor, not bad idea to throw new wear-ring in also...
