rcguy Active Member Nov 1, 2016 #1 I own a Challenger 180 and I would like to change the engine coolant. Has anyone done this before and what is the specific procedure?
JPass Well-Known Member Nov 1, 2016 #2 Not a Challenger, but procedure is same. OEM coolant is pricey. I was told any aluminum engine compatible antifreeze will work. I just ordered some from Amsoil as it was less than half the cost of OEM and I'll be doing this flush soon. https://www.youtube.com/watch?v=OzGqZ1SCkDo
rcguy Active Member Nov 1, 2016 #3 Thanks JPass...3 FT Deep make great self help videos. Just bought Auto Zone coolant for 12.99/gallon. Still $2.00 a gallon cheaper than Prestone. Last edited by a moderator: Nov 1, 2016
JPass Well-Known Member Nov 1, 2016 #4 rcguy said: Thanks JPass...3 FT Deep make great self help videos. Just bought Auto Zone coolant for 12.99/gallon. Still $2.00 a gallon cheaper than Prestone. Click to expand... Just be sure it is safe for aluminum engines. This is from the comment section of the video: "We always use ethylene glycol antifreeze with corrosion inhibitors that are safe for aluminum engines. "
Premix Active Member Nov 4, 2016 #5 Red Line Water Wetter should be able to transfer more heat to the heat exchanger. The drawback is it doesn't resist freezing.
rcguy Active Member Nov 4, 2016 #6 Premix said: Red Line Water Wetter should be able to transfer more heat to the heat exchanger. The drawback is it doesn't resist freezing. Click to expand... Well that is just useless. Well maybe not in South Florida and the Caribbean.
