Just like the rev limiter stops you from reving past 3500 in neutral. Isn't there something with water cooling which doesn't allow higher rpm's. What is the 1/4 line that runs along exhaust?
So, I have been looking at every reference I can find for an answer to that question and if someone else knows better please chime in but all I can find are two functions of the control module that will retard ignition.
1. The neutral safety switch/MPEM will limit rpm's to 3500
2. The MPEM will limit engine top end to 7,200 rpm's
I don't have enough experience with these to know if the exhaust / water side are known to have restrictions or regulators that can cause top end issues with these but I would think that would be a slight performance issue of several hundred rpm's and not 3500 of them.
I need to go finish removing the carbs of my Challenger, after thinking about it this morning and giving how well the boat was running until hour number two yesterday and all else checking out I expect to find the two internal carb filters are absolutely filthy dirty with crud.
Or in other words, there's enough fuel getting by to start the boat and run the idle circuits but restricted enough to not allow for any top end operation. This is bad news as lack of fuel + higher rpms = lean condition. For the sake of knowing I am going to pull and clean those filters, install new 1/4 lines and plugs and go for a ride to test the theory while I am waiting for kits to arrive to rebuild them properly.
Now if I could find a complete kit with mounting gaskets etc...
