Challenger rpm
fredm21
Hey guys! On my 97 challenger 787 i am trying to get my rpm to work. Does anyone know where the rpm sensor is? And how can I test it? Thank you
You need to get a copy of the shop manual. Either become a premium member here or try googling "97 challenger shop manual".
That being said, I believe it comes from the MPEM via the ignition coils
You'll need to verify this because I don't have a wiring diagram for your boat, but on a similar ski (97GSX), it comes off the MPEM, the wire colors are TA-BK, and GY.
Lou
Have you checked the small paddle wheel mounted on the ride plate to be sure it is freely spinning?
That would be the speed sensor.
Just a thought,
Try putting a volt meter on the speedo and have someone spin the paddle wheel. If no reading then the sensor/wire is probably bad. If you get a volt reading then speedo is bad.
Just a thought,
His problem is the tach, not the speed.
i have a detailed wiring diagram for a 1800 challenger 97 model if that will help you out? yes you can test the gauges. I have a detailed procedure that I found that you can try.
