IDoSeaDoo
Hey guys, I've been going nuts over trying to fix my impeller issue. I've broken two vices (one at least will be returned) trying to get my impeller off. I've heated the hell out of it, and still ended up breaking the vice. I've taken two different impact guns to it, nothing! But even if I were to get it off, I'd still have to send it off as one blade has a small piece missing from it. I'm pretty sure I can't get away with just cleaning up the edges once this happens, can I?
So to get it sent off would cost around $100. Well, I'm finding impellers online for around teh same price. I'm thinking of just using a spare pump with a new impeller, but WHAT PITCH? Skat Trak says oem is 11/22 and recommends 14.5/22.5 for bottom end or 17/22 for top end gains. My boat cavitated really bad before, so I'm not sure what it's capable of with the oem impeller (not even sure if it's OEM, as it's not straight cut fins, but rather like the swirl) But I'm worried if I get the 17/22 it will take too long to get on plane, vs the 14.5/22.5 is hard to find cheap. I've found a 16/21... what would this do? It says it's for a 720 ski, but could this be a good compromise for bottom/mid range? I want to pull skis this summer and whip it around a lot.
Thanks!
Thanks!
