Challenger check valves.
indianajetfan
Have a fuel problem on my 97 challenger single engine. My question is the parts diagram only shows the twin engine model and no check valve.; My single engine has a check valve which I've discovered is bad. Was that installed by previous owner if not where can I get a number because there are none on it. This should fix my problem because the fuel system is not holding any pressure.
If you are seeing 2 engines... then you are looking at the challenger 1800 parts.
But... I have no idea what you are referring to as a check valve.
