Hi Guys,
Wonder if you can help.
It sounds like there is too much compression. I have a spark, Fuel and have had the timing light out and set the base timing to 8 degrees. It has backfired a few times while trying to start it but in most attempts it only turns over for a second or two before the compression is too great and it stops.
I have been trying to fix the problem with all the adjustments on the throttle arm but no luck
Hope someone can shed some light.
Thanks
Thanks
